D despe. Jan 1, 2020 1 0 10 Jan 1, 2020 #1 I got gigabyte b450 aorus m motherboard and it has a 5 pin input ( 12v rgbw ), and I want to buy a rgb led strip for my pc who has a 4 pin input ( 12v rgb ). So will the rgb led strip work on my rgbw input ? Thank you .
Solution cin19 Jan 1, 2020 Yes, you can. And make sure the strip is not more than 2m or does not draw more 2Amp. Check out the manual page 14. https://www.gigabyte.com/us/Motherboard/B450-AORUS-M-rev-10/support#support-manual
cin19 Titan Mar 14, 2011 15,722 217 112,340 Jan 1, 2020 Solution #2 Yes, you can. And make sure the strip is not more than 2m or does not draw more 2Amp. Check out the manual page 14. https://www.gigabyte.com/us/Motherboard/B450-AORUS-M-rev-10/support#support-manual Upvote 0 Downvote Solution
