Does a 500W Intex Spider power supply is enough for an AMD FX 6350 and a gtx 560TI/650TI/660/670?
osvii
24
Also 2 x Kingston 4GB 1600MHz DDR3 Non-ECC CL9 DIMM HyperX Blu
ASRock 970 EXTREME3 R2.0
Flash SSD Kingston V300 2.5", 120GB
I'm not sure I would trust an 'Intex Spider' to power a flashlight. Get something decent. Corsair, Seasonic, PC Power and Cooling, XFX, Silverstone, Enermax, OCZ, Antec or the high efficiency Rosewill units.
That one I'd trust to recharge some AA batteries. But only one at a time.
As anort3 said before...get a good one.
So, witch one is better Cooler Master B600 600W(not modular) or Thermaltake Smart SE 530W (modular)?
It has to power an gtx660.
They both have 2 x PCI Express 6+2 pin, witch is required to power the gpu, right?
As a case i'm going with a middletower Zalman Z9 U3.
Neither. Thermaltake and Coolermaster are brands to avoid when it comes to power supplies. There are a few good higher end models but those are not among them.
The Corsair is good and the Sirtec is OK.
f---, i never thought choosing a psu will be so hard.
OCZ ZS Series 550W
OCZ ModXStream Pro 500W
Corsair Builder CX500 V2 500W
Corsair CX500M
if this aren't good either i quit
Mod edit: Keep the language family friendly 😉
Lol. Any of those are good. I would pick :
1) OCZ ZS
2) Corsair CX500M tied with --->
2)OCZ ModXStream Pro
3) Corsair CX500 V2
Thanks, now we are getting somewere
Out of all psu's that i mentioned and this two
Corsair Builder CX600 600W, Corsair VS Series VS650 650W witch one should i buy, kepping in mind that maybe sometime in the future i will overclock my cpu/gpu
Sidenote: thanks for your quick responses and willingness to help
I would go with the VS. The regular CX series ( not the CXM ) uses cheap Chinese made capacitors. It's still a good unit but they can die when stressed.
Glad to help! :)
