h9dlb :
I5-750 clocked to 3.5ghz - desktop case with front and rear fans
you're already running at 60c with the fan running?
nope. you won't be able to run fanless. frankly you're running too hot WITH the fan. What i mean is your overclock is not extreme, you should be running cooler then this (not that it's a dangerous temp, just that your cooler should be working better then that)
