Hey guys,
i'm looking for a very smart person that could tell me if an Ethernet repeater (these cheap ones) you can buy online would work to boost signals on an Ethernet cable with communication, other than tcp/ip. like do they just boost every signal and instantly relay it to the other side or is there more electronics in there to cope with signal skew etc...
old setup:
machine <==>ethernet cable 1m><==> control panel
desired setup: (5m still works)
machine <====>ethernet cable 20m and more<====> control panel
from what i know, 2 pairs are used to power the control panel, the rest are signal wires.
suggested setup:
machine <====>ethernet cable xxx meter<====> repeater <====>ethernet cable xxx meter<====> control panel
also possible is to power the control panels myself where they are located and only use/boost the signal wires
thanks for reading Mitch
old setup:
suggested setup:
