Does a FX 8320 Come with a cooler
Unless the listing for the FX8320 specifically states, "OEM", then it should include a cooler and yes, a cooler is required for ANY operation of the CPU.
-Wolf sends
yes it comes with a cooler.
will it be fine for no overclocking? yes
will it annoy you with the sounds of higher rpm's? probably
is it pretty much junk? yes
is a 8350 way better for people that dont want to overclock? yes
should you get a cooler master hyper 212 evo? yes
FX 8350 is going a bit over my budget but ok thanks..
