Does a Gigabyte Gtx 780 fit a Zalman Z11-Plus case?
DId it fit? Because I'm also going to use that setup.
I got the gigabyte 760 and I am pretty sure that it is the same size as the 780 and it fit, barely. Like I can only fit a small wire in between the GPU and HDD case.
Yeah a smaller card would be nice for the space and the zalman isn't the greatest for space. But the gigabyte so far has amazing cooling and is running above the specified performance of what others said it would. Really just all preference and not too big of a difference either way you go.
What temps are you getting out of it? The Asus 760 idles at 30 in this case
Mine also idles at 30
Cool, max mine has hit it 67 or so running Far Cry on max, but of derailing OP's threads *inserts thread derailed pic*, back on topic
