I need to check if my power supply and motherboard will work with a gtx 960.
My Specs:
Intel core i5 3570
Ocz Power supply 500w
8gb ram
Asus H61M-A/USB3 Motherboard
GT 630 (4bg) Needs to be updated!
So the power supply specifications :
500W Configurations
Dual +12V Rail
Continuous output rated at 30°C
150 x 140 x 86mm (W x L x H)
ATX12V v2.2 compliant
Non-Modular
80% efficiency at typical loads
Heavy-duty protection circuitry including over-voltage, over-power, and short circuit
Active PFC
ErP compliant for low power usage in standby
120mm temperature and load controlled fan
MTBF: 100,000 hours
3-year warranty
Connectors
1 x 20+4-pin ATX
1 x 4+4-pin ESP/12V CPU
1 x 6+2-pin PCI-E
1 x 6 pin PCI-E
2 x 4-pin Peripheral
4 x 5-pin SATA
1 x FDD
On the power supply it has 5 different voltages which are:
20A 15A 25A 0.3A 2.5A
1. I was wondering if this power supply works with this graphics card. - http://www.amazon.co.uk/Ocz-Corexstream-Power-Supply-500/dp/B007N9YKDO/ref=sr_1_1?s=computers&ie=UTF8&qid=1427135590&sr=1-1&keywords=ocz-cxs500w
Asus Motherboard Specifications:
USB 3.0 Boost - Faster USB 3.0 Transmission with UASP(170%)
HDMI & DVI Outputs - High-definition Visual Enjoyment
DIGI+ VRM Digital Power Design
UEFI BIOS - EZ Mode - Flexible & Easy BIOS Interface
EPU - Energy Efficiency All Around
Superior Components -100% All Solid Capacitors & Extra Durable Stainless Steel Back I/O
Learn more about the ASUS H61M-A/USB3
Model
Brand
ASUS
Model
H61M-A/USB3
Supported CPU
CPU Socket Type
LGA 1155
CPU Type
Core i7 / i5 / i3 / Pentium / Celeron (LGA1155)
Chipsets
Chipset
Intel H61
Memory
Number of Memory Slots
2×240pin
Memory Standard
DDR3 2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1600/1333/1066
Maximum Memory Supported
16GB
Channel Supported
Dual Channel
Expansion Slots
PCI Express 3.0 x16
PCI Express x1
Storage Devices
SATA 3Gb/s
4
Onboard Video
Onboard Video Chipset
Supported only by CPU with integrated graphic
Onboard Audio
Audio Chipset
Realtek ALC887
Audio Channels
8 Channels
Onboard LAN
LAN Chipset
Realtek 8111F
Max LAN Speed
10/100/1000Mbps
Rear Panel Ports
PS/2
Video Ports
D-Sub + DVI
HDMI
1 x HDMI
USB 3.0
2 x USB 3.0
USB 1.1/2.0
2 x USB 2.0
Audio Ports
3 Ports
Internal I/O Connectors
Onboard USB
6 x USB 2.0
Other Connectors
1 x CPU Fan connector(s) (1 x 4 -pin)
1 x Chassis Fan connector(s) (1 x 4 -pin)
1 x 24-pin EATX Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Internal speaker connector(s)
Physical Spec
Form Factor
Micro ATX
Dimensions (W x L)
8.9" x 7.1"
Features
Features
ASUS DIGI+ VRM
ASUS C.P.R. (CPU Parameter Recall)
ASUS EPU
Anti-Surge Protection
ASUS AI Suite II
AI Charger+
USB 3.0 Boost
ASUS Disk Unlocker
Network iControl
Fan Xpert
UEFI BIOS EZ Mode
ASUS Crash Free BIOS3
ASUS EZ Flash 2
ASUS MyLogo 2
100% Solid Capacitors
I know i didnt need all of this but its just for people to look at to see if its compatible
2. Need to know if this asus motherboard is compatible. - http://www.amazon.co.uk/Asus-H61M-A-Motherboard-Socket-SATA-400/dp/B00BPL0FJ4
Thanks for any feedback given, i know this is a long paragraph but its there just in case. Thanks!
My Specs:
Intel core i5 3570
8gb ram
500W Configurations
Dual +12V Rail
Non-Modular
Active PFC
MTBF: 100,000 hours
3-year warranty
Connectors
1 x 20+4-pin ATX
1 x 6+2-pin PCI-E
1 x 6 pin PCI-E
4 x 5-pin SATA
1 x FDD
Model
Brand
ASUS
Model
H61M-A/USB3
Supported CPU
CPU Socket Type
LGA 1155
CPU Type
Chipsets
Chipset
Intel H61
Memory
2×240pin
Memory Standard
16GB
Channel Supported
Dual Channel
Expansion Slots
PCI Express 3.0 x16
PCI Express x1
Storage Devices
SATA 3Gb/s
4
Onboard Video
Onboard Audio
Audio Chipset
Realtek ALC887
Audio Channels
8 Channels
Onboard LAN
LAN Chipset
Realtek 8111F
Max LAN Speed
10/100/1000Mbps
Rear Panel Ports
PS/2
Video Ports
D-Sub + DVI
HDMI
1 x HDMI
USB 3.0
2 x USB 3.0
USB 1.1/2.0
2 x USB 2.0
Audio Ports
3 Ports
Onboard USB
6 x USB 2.0
Other Connectors
Physical Spec
Form Factor
Micro ATX
Dimensions (W x L)
8.9" x 7.1"
Features
Features
ASUS DIGI+ VRM
ASUS EPU
ASUS AI Suite II
AI Charger+
USB 3.0 Boost
ASUS Disk Unlocker
Network iControl
Fan Xpert
UEFI BIOS EZ Mode
ASUS EZ Flash 2
ASUS MyLogo 2
