Does a Higher TDP CPU get Hotter than a Lower TDP CPU?
HappyHambo
175
Simple (and possibly stupid) question. If I was to get a Intel Core i5-4690S with a TDP of 65W would it run cooler than a non-overclocked Intel Core i5-4690K with a TDP of 88W?
Im new to PC building and really not sure about his sort of stuff 😛
Yes, a higher TDP means that the component outputs more heat and thus requires better cooling solution for the same temperatures.
Though the TDP of the 4690s and the 4690k is that different - in real life they will be very very close to each other.
Better get the 4690k and just get an aftermarket cooler for 20-30 bucks. It is a wise investment.
I would never put Intel stock cooler for the long term on anything higher than I3.
So 4690S isn't worth it?
For performance (everybody wants that right), you should always get the higher TDP unit, UNLESS you are building a smallish case, you are really constrained on the cooler you can install. At idle, both cpu temp will be, for all practical purposes equal, is only when you push them, that means the higher TDP CPU "has another gear" to put it in automotive or horse racing terms.
Reactions: JoBalz
