does a lower color depth (16bit versus 24bit versus 32bit) get significantly better frame rate in games?
giantbucket
Dignified
BANNED
so if i have an older graphics card, does doing a global color depth in windows get me better frame rates in games? my eyes probably can't differentiate 98732696991879283749817239846 different colors, or even 50 shades of blue, so i'm thinking - why bother forcing the hardware to display stuff i can't even see?
does anyone have ideas on how much of a boost (in frame rates) i'd get by reducing the color depth from 32 to 24 or 16? would it basically be proportional, like double the frame rate if i drop from 32 to 16 bit color?
No, it won't 'double'. I expect some value between 0 and 1. Probably closer to the 0.
Why don't you try it and see what happens? Report the results back here.
ok, i did a quick test (go from 32bit to 16bit) on my laptop which runs an NVS4200M chip (as well as the i5-2520M). no change. so, why? isn't it far easier for the hardware to process using only half of the color information? or is the hardware only doing the calculations / rendering / whatever based on geometry?
It's the same number of pixels.
Now...if you reduce to 640x480, you might (up to a point) see better FPS.
The simple reason is that the color information isn't all that strenuous a task. Think of it as peeing in the ocean twice versus peeing in the ocean once - just because you doubled your urine output doesn't make a noticeable difference because the ocean has so much other stuff.
Not sure why I chose that analogy. Possibly because I kinda have to go to the bathroom now.
Your basically right, rephrasing DSz just showing something is easy, your television can simply display stuff without any computing power, you don't need a computer to watch a movie, but to create that movie, that requires immense power over long periods, let alone to do it instantly in real time
ok, makes sense. so, is there a "priority" listing somewhere that shows roughly what has the most impact on achievable frame rate, going from largest impact to minimal? that way, i (we) can figure out what to turn down first to get decent rates on older hardware.
Not sure about a priority listing, but anti-aliasing options are the first thing to turn down. Then stuff like shadows and textures. It varies a bit from game-to-game and in some games, turning down certain options looks better than other options and vice-versa.
