Question does a negetive voltage offset worsen cpu transition voltage?
Mahbub1
433
ok so i have a 9700k and i set a negetive offset of -0.070v and it gave me better temps.. but when i digged the internet someone told that setting a negetive offset helps temps but it worsens the "cpu transition voltage" which can degrade cpu in long run.. i have no idea what "cpu transition voltage" is.. so like can someone explain to me.. also does setting voltage offset really isint safe? i dont plan to overclock or anything.. so should i keep the voltage at stock or should i set an offset..?
