Howdy - I've installed a switch at the end of a LAN cable on my home network. If it matters, it's this specific unit:
The purpose of the switch is to share that end of the LAN cable between a PC and a network drive so I don't have to run another cable all the way from the router.
a) if one of the PC wants to access the network drive, does a switch know how to just have them talk to each other directly through the switch? Or does communication go all the way back to the router then back to the other device?
b) If I use the PC to copy files from this network drive to another network drive (not on the same switch), will the transfer speed suffer from bandwidth sharing?
Thanks.
5-Port 10/100/1000Mbps Desktop Switch
TP-Link’s TL-SG105 provides an easy way to expand your wired network. With five Gigabit ports and plug and play, whether you are at home or in the office, the TL-SG105 you deal with your business quickly and easily, any time.
www.tp-link.com
Thanks.
