Does a USB hub drain more battery?
Bruno Vincent
210
I have a laptop and it doesn't have enough USB ports for what I want it to do...
Would buying a an external USB hub drain more battery?
For example:
a.
-Mouse connected to laptop native USB port
-Wifi stick connected to laptop native USB port
b.
-USB hub connected to laptop native USB port
-- Mouse connected to external USB hub
-- WIFI stick connected to external USB hub
I would get a hub with no light on it.
I haven't heard of any USB hub that doesn't require some power to maintain transfer speed. If it doesn't use its own power - by way of a wall plug - it has to draw power from your laptop. How much will depend on the number of USB ports, and possibly the type/generation of USB used.
Cheers,
GreyCatz.
Cheers,
GreyCatz.
