Question Does an SD panel mount device exists?
Mar 17, 2020
55
I need an SD card slot on my computer so I wanted to put an USB to SD converter plugged into my motherboard header than using an extender cable with PANEL MOUNT to an empty expansion slot I would have made a hole in to fit that extender. That way I would have an SD card slot on the back of my computer.
Is there a device such as this for SD cards?
https://www.amazon.ca/-/fr/Adafruit-Panel-Mount-femelle-Ada908/dp/B00DK2CPZS/ref=sr_1_8?__mk_fr_CA=ÅMÅŽÕÑ&keywords=usb+panel+mount&qid=1586004142&s=electronics&sr=1-8
