[SOLVED] Does anyone have a fix for 60hz monitor capping a main monitor at 144hz (Rx5700xt)
Apr 23, 2020
Recently bought a side monitor (60hz) to use with my main monitor (144hz) and whenever the second monitor is plugged into gpu my main monitor is capped at 60hz. I found some Nvidia gpu solutions to this problem but i never found any that would fix my problems with an amd gpu (5700xt).
Is there any way to fix it? im using a 3800x btw
depends on what you are trying to achieve.
if trying to use the displays simultaneously; gaming or other "surround" applications:
you have to use displays with the same refresh rate.
if using them in other scenarios that don't require a "surround" display setup:
depending on the CPU, you can have one attached to the motherboard I/O port(s) and one attached to the GPU.
though this will lead to separate desktops that cannot display the same applications extended across both screens.
Reactions: Kahwws
Reactions: Kahwws
Apr 23, 2020
Thanks so much for the help. And does this mean that if i use another 144hz monitor it will work properly? if so i think ill just do that.
