I’ve recently got this new case and decided to move my parts to the case, but I’ve ran into an issue with these pins and I have no idea how to set them up, there is literally no support for this motherboard at all.
Yessir, I did see that, but I am still quite confused as the diagram is not properly lined up, nor do I know if I put the pins in the JLED2/JLED1/ or the Panel section. (Sorry, I’m new to pc building.)There is a tiny diagram screenprinted just below the PANEL header.
See page 10 here: https://dlcdnets.asus.com/pub/ASUS/mb/LGA1151/H110I-PLUS/E11133_MB_Pin_Definition_v2_web_only.pdf
For the Power Sw, it says power and ground, how would i plug the pin in for that?The manual has the diagram (20-8 pin) properly lined up, you plug them into the PANEL section
Thank you so much man! Helped me so muchThe + would be power, - would be ground (labeled on the actual wire in your first picture)
Generally, the letters should face out.
