UPDATE: Partially solved. See bottom of post for updates.
I recently acquired one of the cheapest LGA 1155 motherboards I could find on eBay for a budget build. I did a similar build with an old Intel board recently and was able to jumpstart it by shorting the power switch pins after locating them using the manual. No problem.
The trouble is, (A) I can't seem to find the power switch pins to jump on this old, proprietary HP Elite 8300 motherboard. Also, (B) I'm not sure if it's fully powered since it uses weird power connectors. Here's a pic:
Those labels are taken from the official HP "Illustrated Parts and Service Map" for this board.
I have the 4-pin CPU power plugged into my Seasonic 400W PSU, to power an i3 3240. Also have 2x4GB DDR3 PC3-12800 RAM in the two slots closest to CPU.
I have the 6-pin "PWR" or "Main Power" plugged in.
I have no idea what that strange 6-pin "PWR CMD" or "Power Connector" is.
There are no signs of life on the board when PSU is switched on, and I can't figure out which pins I should even be able to jump to power on (in the event the board were fully powered.
So to sum up:
-----------UPDATE-----------
I think I've solved the problem of how to power the board - need to use a 24-pin to 6-pin power adapter like this one. Still don't know how to turn the thing on without a case switch though.
-----------UPDATE 2-----------
I think I found the header I'll need to jump - the black header in the lower right corner is the power button/LED header. I still don't know precisely which pins on the header to jump, because they're not individually color-coded or identified in the manual.
So to sum up:
- I don't know if I have the board fully powered, and
- I wouldn't know what pins to jump to turn it on if it were fully powered.
