Hi,
I am looking to get in to water cooling and have read a lot of good things about this system (keep in mind this will be my first time so I have no interest in building my own or buying part by part at the moment).
My questions are if you use this is it pretty good? I'm currently on (do not laugh I've only had my core 2 duo 4 days =o) stock heatsink which was a royal pain in the !#@$!#@ to install ... and isn't sufficent to do much OC with.
My build is this:
Case = Thermaltake Armor Series VA8000BWS Black Aluminum/Steel ATX Full Tower Computer Case
Motherboard = ASUS P5B Deluxe/WiFi-AP Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard
PSU Unit = HIPER HPU-4B580-MS ATX12V 580W Power Supply 100 - 120V
Video Card = eVGA 512-P2-N635-AR Geforce 7950GT 512MB 256-bit GDDR3 PCI Express x16 Video Card
Memory = GeIL Ultra 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit
DVD = LG 16X DVD±R Super-Multi DVD Burner With 12X DVD-RAM Write Black E-IDE/ATAPI
CPU = Intel® Core 2 Duo E6600 Conroe Processor 2.4GHz, 1066FSB, LGA775, 4MB Cache
HD = Western Digital Raptor WD1500ADFD 150GB Serial ATA 10,000RPM Hard Drive w/16MB Buffer
I have plenty of room in the case and it even sorta has spots setup for the cooling units also. I was going to go with the Thermaltake unit for $150 but a few guys have recommended this one instead.
I want to basically (who doesn't??) push this core 2 duo as far as it can go and remain stable, but also I have several boxes in my office kvm'd and such and the heat gets worse with each addition. This would also help with that.
Is my setup good for this? I do not want to mod my case or anything. Newegg is out of the unit often but I do not mind paying $30 more from the swiftech site or anything.
Also, is it in my best interest to get the ultra edition which comes with the chipset/vga cooling units too, or save that for later as an expansion project (is that even possible with this unit?) or I could always use other cooling devices on them.
Thanks for your time. Don't flame the noob too much ..... =]
My build is this:
Haven't made my decision 100% yet.
