[SOLVED] Does aorus pro z390 pro recognize ramspeed over 2133??
Euroman28
213
9
4,595
I am waiting a aorus pro z390 pro in the mail today to replace my Asus Z370-p . Is it true that the aorus pro z390 pro reads memory sticks with speeds over 2133 mhz (with out the system is OC)? Unlike my current board which reads my 3000 mhz ram as 2133 mhz if I don't active XMP profile.
I think he means that he has to activate XMP Profile to achieve the 3000mhz speed, otherwise it's recognized as being 2133mhz.
To OP: The (O.C.) which follows all the speeds listed indicates those are OverClocked speeds, which requires activating the XMP Profile. The Gigabyte Z390 Aorus Pro will not automatically operate your RAM at those speeds by default. Meaning that you will have to enable the XMP Profile from the system's UEFI BIOS. It's very easy to do, however.
When you boot the computer, press the Delete key while it's booting up to enter the BIOS. If you see the Aorus bird on your screen, start stabbing Delete & you should enter the BIOS if you were fast enough. If not, simply restart & this time be ready. You can spam...
Support for DDR4 4266(O.C.) / 4133(O.C.) / 4000(O.C.) / 3866(O.C.) / 3800(O.C.) / 3733(O.C.) / 3666(O.C.) / 3600(O.C.) / 3466(O.C.) / 3400(O.C.) / 3333(O.C.) / 3300(O.C.) / 3200(O.C.) / 3000(O.C.) / 2800(O.C.) / 2666 / 2400 / 2133 MHz memory modules
https://www.gigabyte.com/Motherboard/Z390-AORUS-PRO-rev-10/sp#sp
When you boot the computer, press the Delete key while it's booting up to enter the BIOS. If you see the Aorus bird on your screen, start stabbing Delete & you should enter the BIOS if you were fast enough. If not, simply restart & this time be ready. You can spam that key the second it restarts & it'll be fine.
