Does ASRock Z390 Pro Support LED fans?
Dec 27, 2018
I’ve built a system using a ASRock Z390 Pro MB inside a Phantek
ProM case. Everything seems to work fine but I cannot figure out
how to make the fan LEDs work. The MB doc has no mention of
RGB support (if that’s the correct term). I see the 4-wire LED cable
(has 2 4-pin connectors) in the case but I can’t figure out where on
the MB this is supposed to go. This isn’t a show-stopper but my son
would like it working for the “cool” factor. 🙂
I don't see an RGB header listed for that board in the manual. You can buy RGB controller, tho to add that function to the system.
