does asus h110m-d will support 2400mhz max speed in kaby lake and xmp?
wolframazer
71
I already bought a single hyperxfury 4gb ddr4 2400mhz c15, and I read it in the mobo asus website that a maximum ram speed is 2133mhz but thats is my speed if i put only a skylake cpu but what if I put a kaby lake? the mobo bios is already updated because I see it have 3016, I'll put a g4560, anyway this is all I can afford so pls dont suggest more high end boards, it hurt my feelings
If you look at the GA-H110M-DS2 Memory Support List, it lists support for "DDR4 2400MHz (downgrade to DDR4 2133MHz)".
So the memory will work, but at the reduced speed.
I search in another board in gigabyte, h110m ds2 in skylake the maximum speed is 2133mhz but if I need to get the 2400mhz I need to change my cpu to kaby lake? but that gigabyte doesn't have xmp feature
ok that's sad yeah I see that in top of list now maybe I should buy the cheapest gigabyte b250m board, maybe the board will not downgrade my ram right? by the way I use it to play dota and old games, I will use a palit gtx 1050 ti oc dual, the only processor I could afford is g4560, mobo and processor is the only missing in my build
A B250 motherboard should allow RAM to run up to 2133mhz with a Skylake CPU, and 2400mhz with a Kaby Lake CPU.
tnx sir but thats ridiculous if I paired it with g4560 hahaha, tnx for your help sir I will save my money, maybe I go to ryzen or core i3 cofee lake, but intel are still expensive because of mobo
Either way i don't think you would notice much difference between 2133mhz and 2400mhz RAM.
