Thanks for your quick reply! The Asus Strix Nvidia GTX 980 I am going to buy will be already OCed when it comes out of factory, because the Asus website calls it the "Overclocked Edition" ...
Link-[https://www.asus.com/in/Graphics_Cards/STRIXGTX980DC2OC4GD5/]
So do I need a water cooler? If so, which one? Any thing I can easily find in India?
I am a newbie and this will be my first custom build. So thanks for helping me out...
Also I found out that The Asus Rampage V extreme would be an Extended ATX (E-ATX)... So I wanted a good case. And being fan of NZXT I found two cases of my liking
1.NZXT Phantom Full size tower (https://www.nzxt.com/product/detail/34-phantom.html#)
2.NZXT Phantom 820 Ultra+ size tower (https://www.nzxt.com/product/detail/96-phantom-820-full-tower-case)
I may be getting a triple GPU later on, so I want to accommodate that also, with a water cooling unit which I will be purchasing after I OC my Processor in a year or two... So can you suggest the better case from the two, I am inclined towards the Phantom 820 one, but please let me know if the Phantom one will do...
And also please let me know if my CPU might need water-cooling. I mean when I game I expect it to heat quickly... Or am I wrong? I thought of the DeepCool Gamer Storm Captain 360 AIO Cooler if i go for the Phantom 820 or the DeepCool Gamer Storm Captain 240 AIO Cooler for the Phantom...
But I will be buying none of these If i need to water cool my OCed Asus Strix Nvidia GTX 980, as then I will need to buy a water-cooling kit... Speaking of a kit, I plan on going for EKWB's kits.. So can you suggest which kit would go well with each case if I need both CPU and GPU to be water-cooled. Also let me know which water block will fit the Asus Strix Nvidia GTX 980...And whether I need to do some modifications to the GPU to fit the water block or not? If I need to do some modifications to it by removing the air cooler provided by Asus present on the GPU, Then, I needn't go for the Asus itself... Am I right? If so, also let me know other Nvidia GTX 980 GPUs that will need no modifications or very less modifications to fit the water water block to water cool...
Update: I also have poor knowledge of Computers and hence can you also let me know If the RAM needs cooling? I plan to go for Kingston HyperX Fury DDR4 2133 2x8GB... So I will get a 16GB RAM.. I might be dual booting my Computer, that's why I need 16GB, I thought of going for 32GB but decided I may go out of budget, so I plan to decide that after getting the cooler and PSU, depending upon how much is left in my budget... And finally, I will be going for WD Caviar Green 3x3TB.. So also let me know how many watts my PSU needs to be after I OC everything...
