Does Comcast require a coaxial outlet for installation?
Erudition
8
I searched through the Internet, but I couldn't find a straight answer. A technician is coming over on Sunday to install 75 Mbps Internet with Comcast's provided gateway (modem/router hybrid), but both of my coaxial outlets are blocked by beds. Before I go moving around one of the beds, I am wondering if they require coaxial outlets at all. I looked at the self-install video, and it indicates that they do, but I also read that they can apparently route some sort of cable without the need for a coaxial outlet. I plan on using Ethernet cables (Cat 6 or 6a) for my devices (PS4 and probably two MacBooks).
As it is a cable connection, it does require a coax. And a box on the outside of the house.
Where this is matters not, mostly...
There is a coax line from a box at the street.
This runs to a box on the side of the house.
From there, inside.
If this is a single family residence, they can put the box and incoming coax port wherever you want.
If this is an apartment or condo, things may be different.
Yes a coax is needed because that's how the signal comes in.
If this is a new installation, the guy will run a coax cable from the pole to wherever you want, somewhere with an outside wall and makes a coax plate for you.
However since you already have coax connections into your inside, I wonder if the installer is willing to go to all the trouble of running another cable, just because you don't want to move beds.
