devor110 :
Why would you vote him down? Explaining how to set it up was not my question because I am currently using this setup which is clearly written down.
While you and 13thmonkey know how to use this setup, the explanation is for everybody else that may come to this topic in hopes to get their same setup running. Without any explanations how it's done, it isn't helpful for others and hence the vote down.
In graphical aspect, both monitors have their own GPU to power them and in that sense, there should be a slight performance increase. But since your 2nd monitor is run off by iGPU, it puts a higher load on a CPU and that can drop the CPU's performance. Without testing (benching), it can't be said for sure if this setup would drop the PC's overall performance or not.
Since you have your setup running, you can easily do some benchmarks with only one monitor running and then with 2 monitors running to see if there is any performance drops or increases.
