I have an auxiliary computer at home which is not my main desktop PC, but which I use occasionally for small tasks.
The computer is 6 years old.
The CPU is i7-3770S with a stock cooler.
Few days ago I (almost accidentally) launched Intel Desktop Utility and it indicated that CPU temperature at idle state was about 58-61 Celsius.
I later confirmed it with HWInfo that displays the same value.
When I run moderate load (about 50% as indicated by Windows Task Manager), the temperature stays about the same, in the 60-65 range.
When CPU is loaded fully, it quickly goes towards 90, but I did not try to see how high it would creep up.
I used BIOS to adjust CPU fan speed to 100% but it does not have an effect on CPU idle temperature.
I vaguely recall that when the computer was just built 6 years ago, I ran integrity and stress tests and temperature did not look a concern, i.e. idle temperature was probably somewhere in 35-45 range back then (I do not recall exactly what it was, but somewhere in this range).
I am at a loss what could cause the change.
Could it be that the grease somehow degraded over time and does not conduct the heat to the cooler sink well any more?
