Does Dark Rock Pro 2 fit?
Trauber
Heloy,
I'm about to buy a new CPU-cooler.
I decided to give the Dark Rock Pro 2 by be quiet a try and would like to know if it will fit in the following system without causing trouble:
Motherboard: Msi Z87 G45 Gaming
RAM: Corsair Vengeance Pro (2x8GB)
Case: Cooler Master Silencio 650
CM says its case supports a height of up to 168mm.
How accurate is this, can I trust this statement?
Also, do you know if there will be problems with the high profiled RAM if I put it in the slots that are the furtherest away from the CPU?
Hope anyone has experience or knows his stuff,
so thank you already,
Trauber
Your going to need low profile RAM with that cooler but not to sure if it will fit in the case. I have a corsair 300R and have a phanteks that has a height of 157mm so you could try work out the differences.
