Does Display (VGA) Converter/Adapter makes a difference?
muelltfz
28
I was looking for a DVI-D to VGA adapter for my GPU and monitor and THEN i thought that should i just go with a better display adapter like Display port to VGA adapter but then i realize its still going through my VGA monitor and maybe its still going to convert it as VGA either way.
so having a better display adapter makes a difference even its still converting VGA?
Which is better DVI-D to VGA or Display Port to VGA? is it still the same?
Please answer thanks!
hey Paul thanks for answering im new to this stuff what exactly do i need?
paul thanks i didn't even know bout these stuff and i was gonna buy a dvi-d to vga converter without knowing it will never works cause its not an active adapter. thanks to you. but my point about this thread is the difference about picture quality, better sync, better refresh rates? do display port to vga vs dvi to vga makes a difference or they're going to be just plain VGA anyway? dont care about sound though cause i have it on my motherboard.
