[SOLVED] Does fan speed matter?
ManjotMANN
51
I have a fan controller built into my corsair spec alpha case and I have 2 front and one exhaust(rear) fan connected to it does turning the fan speed down cause any problems?
I'd say you'd probably like to keep your cpu running within a good temperature range. Possibly 50 - 65 ish.
If you want to reduce your fan speeds, etc. Because of noise or excess power, already good temperatures.
Yes you can do this, just watch your temperatures whilst gaming for the first few session, also don't tinker around and lower any fans specifically lower or higher than others, you'll want the same input/output ratio as before.
I just want to change Case Fan speed and my cpu idle is 30c and underooad never goes above 45
