Hi Guys,
I have been IT guy for many years and relatively recently I started gaming again after ~15y brake.
Wow, there is a difference, no words
But after half year of gaming, and after build new PC for myself (first I built for my son), I’m little confused about stuttering in games, so I would like to kindly ask you guys for an opinion.
On the beginning of my “come back”, on first gaming rig (son’s rig) I never paid attention to FPS drops, so I didn’t notice any stuttering issue (monitor 60hz). But after building my second rig (spec below) it start to be visible, probably because monitor ref rate (165Hz), and/or my eyes upgraded 😉
I though this is some issue with my new build (my wife say it’s too powerful), but after tons of tests (with my first and second build), my final conclusion is that fps drops (smaller or larger stutter) is something normal in most games, and we have to play around every time with all graphics options (nvidia cp, in game options, OS, drivers, OC) trying minimize it (if you care). In some games we can successful minimize it (so they are not visible), but sometimes we simply can’t rid of it (like in BF5, SW Fallen order). What is your experience? Do you think framerate spikes are normal or is it h/w related thing (and I have simply bad luck with my both builds)?
What I have done for testing:
clean OS install (W10)
OS optimization for gaming (playing with multiple options and things)
different GPU drivers (and not only GPU)
overclock, downclock CPU/GPU
different BIOS versions and configurations/parameters
replace GPU/RAM/SSD/monitor
I tested my son’s rig and now I also see stuttering on his PC (much less visible because of 60Hz, but when I connect my monitor 144Hz stuttering is larger than on my rig).
PC spec:
Intel Core i9-9900KS, 4GHz, 16MB, BOX (BX80684I99900KS)
Gigabyte Z390 AORUS MASTER
G.Skill Trident Z, DDR4, 32 GB (4x 8GB),4000MHz, CL18 (F4-4000C18Q-32GTZ)
MSI GeForce RTX 2080 Ti GAMING X TRIO 11GB GDDR6
SSD Samsung 970 EVO Plus 1TB M.2 PCIe x4 NVMe (MZ−V7S1T0BW)
SSD Intel 660p 1TB M.2 PCIe x4 NVMe (SSDPEKNW010T8X1)
Cooler Master MasterLiquid 360R RGB (MLX-D36M-A20PC-R1)
Cooler Master MasterCase H500M (MCM-H500M-IHNN-S00)
be quiet! Straight Power 11 1000W
Monitor Asus PG279Q
3x Noctua PWM 120mm (NF-A12x25 ) (for replacing MasterLiquid 360R stock fans)
PC spec (first build):
Intel Core i7-8700, 3.20GHz, 12MB, BOX (BX80684I78700)
Stock cooling
Gigabyte Z370 AORUS Gaming K3
G.Skill Ripjaws V, DDR4, 16 GB (2x 8GB),3200MHz, CL16 (F4-3200C16D-16GVKB)
Palit GeForce RTX 2060 GamingPro OC, 6GB GDDR6 (NE62060T18J9-1062A)
SSD Samsung 970 EVO 500GB PCIe x4 NVMe (MZ-V7E500BW)
be quiet! SILENT BASE 601 | BLACK
be quiet! 500W PURE POWER 11CM BN297
Monitor LG 27MP59G-P
PC spec:
Monitor Asus PG279Q
Stock cooling
