Does geforce gtx 770 need water cooling?
MadGamerG90
30
Im buying a 17 4770k along with zotac gtx 770......does gtx 770 need a water cooling system ? or is air cooler enough to keep it cool? Im planning to OverClock it later!!
No it does not need it - but if you plan to and are in the US get a MSI card since you will retain warranty if you don't physically damage the card changing the cooler to a waterblock
EVGA doesn't void warranty if you install a waterblock, as long as you register the card within 30 days of purchase. Even if damaged DUE to watercooling. Trust me, I've done it.
And most cards don't NEED watercooling, but they need cooling of some sort, which is why they come with fans installed. If this is a discussion of 'need' vs. 'is it beneficial?', then that should be determined.
