Does Gigabyte G41 Combo Motherboard has a System Speaker Port?
hishara1999
81
Is there a system speaker port in Gigabyte GA-G41M-Combo Rev 2.0 motherboard to hear POST beeps when something goes wrong?
For example, when I insert a bad RAM stick, I must have a system speaker installed in order to hear beep sounds to identify a memory failure.
I am asking because I cannot identify where is the system buzzer ( motherboard buzzer connector ) port in this motherboard.
I am searching for the right connector to connect a system speaker to this motherboard like this:
Please help me.
the 4 pins opposite the power led pins on the front panel port. white block with pins in the bottom corner beside the three SATA ports. labeled "+SPEAK-"
Thanks! Now I found it! I didn't find it because it is labeled in very small letters. Can you please recommend a working model of buzzer for that connector from eBay?
Thanks again, then after installing it, how can I test if it works? How can I get an example beep? Will a CMOS reset produce a beep from it?
Ha ha.....😀😀😀........I will purchase one and test it.....Thanks for your help.....
