M MegaSamGames Reputable Nov 16, 2015 3 0 4,510 Apr 25, 2016 #1 I just bought 2 EVGA 950's and have a SLI bridge on the way, but I was looking around and found out that not all motherboards work with SLI. Does the GA-970A-UD3P?
Solution Ethanh100 Apr 25, 2016 according to PC Part Picker, unfortunately no it does not , only crossfire(AMDs version of SLI). see in screenshot here: http://imgur.com/ePeQE6e
Ethanh100 Honorable Jun 10, 2014 1,208 1 11,965 Apr 25, 2016 Solution #2 according to PC Part Picker, unfortunately no it does not , only crossfire(AMDs version of SLI). see in screenshot here: http://imgur.com/ePeQE6e Upvote 1 Downvote Solution
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Apr 25, 2016 #3 No, that board does not have SLI support. Upvote 0 Downvote
M MegaSamGames Reputable Nov 16, 2015 3 0 4,510 Apr 25, 2016 #4 Ethanh100 : according to PC Part Picker, unfortunately no it does not , only crossfire(AMDs version of SLI). see in screenshot here: http://imgur.com/ePeQE6e Aww, that sucks. I guess I'll be running off of one card until I can get a new motherboard. Thanks for helping me out though. Upvote 0 Downvote
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Apr 25, 2016 #5 Or you can return both cards and get a single, more powerful card (which is the far better option) Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,817 1,870 159,590 Apr 25, 2016 #6 It's still a great AMD FX board. Upvote 0 Downvote
M MegaSamGames Reputable Nov 16, 2015 3 0 4,510 Apr 25, 2016 #7 Gam3r01 : Or you can return both cards and get a single, more powerful card (which is the far better option) I bought them used so I'm not sure if I could return them. Upvote 0 Downvote
