[SOLVED] does graphics card which draw power from the motherboard heat the mobo UP ??!
ziad ahmed
i'm having issue with my mobo's PCH temp
i have 1050TI which draws maximum 75W of the board , does that help the chipset to get heated ?
No.
All graphics cards draw UP TO 75 watts from the slot and then the rest from the pci-e cables.
So a card that takes only from the slot won't make the chipset any hotter, though either way you shouldn't worry about chipset temps, unless you find them to be too high.
No.
