Does gsync decrease input lag? And does a 144hz refresh rate help with screen tearing
Chaingunchris
472
Do I really need gsync for decreased tearing or do I just needs 144hz refresh rate? If 144hz helps with screen tearing, how bad is the screen tearing compared to gsync?
G sync should have the same input lag as if you were running a game at the monitors max refresh rate. Gsync completely gets rid of Lag from V sync and tearing without v sync.
Does a 144hz refresh rate help with screen tearing? If so, how much less does it help than gsync?
From what I've heard a little bit, but the tearing will still be visible even at 144hz.
