does gtx 950 work with 300w psu
Depending on the model of GTX 950, you'll need a 6-pin or 6+2-pin PCIe power cable. I don't know of any 300 watt power supplies that have those. You should consider a good quality 400-450 watt PSU as minimum.
No, minimum is 350W and recommended is 400W.
If you are gaming make sure you have a Tier 3 minimally for these low wattage's, if not your PSU may blow later on or have other issues including seriously damaging your more expensive parts.
I have a Thermaltake Litepower 400w psu. I am going to buy and MSI gtx 950 real soon. Will my psu be safe for this card?
I have a core i5 3470 and 8 gigs of ram. I won't overclock anything ever. Just want to run everything at stock settings. Will it be safe?
