Does gtx 960 is compatible to handle 1440p resolution dell u2515h monitor??
Mar 20, 2018
6
I have dell U2515H 1440p monitor and gtx 960 graphics card...max. time when i play a high graphics game like....kingdom come deliverance....there is lot of frame drop occurs...i don't understand how to fix this frame drop???
A GTX 960 isn't powerful enough to run a lot of games at 1440p, especially demanding ones like KCD. You could try running games at low/very low settings if you want native resolution. If you have the 2GB GTX 960, it might be difficult to get a good frame-rate at 1440p at all.
Bumping the resolution down to 1080p would likely yield the best results.
I change my resolution 1440p to 1080p and also change my graphic setting from ultra to high...bt same thing happens again and this incident occur for heavy graphic game like kingdom come deliverance bt like sniper elite 3 that incident not happens
