My Pc kept shutting off. Repairman said hard drive was missing pin. Cable was never out, so am puzzled. Will this be a reason for problem. Can it be fixed?
It can be fixed but I doubt it's your hard drive check other components first what hand drive are you using. If you can check cpu or GPU temprature as often computers can just off when they over heat. If you could give us more detail on the specs of the computer it might help.
