[SOLVED] Does Having Bigger GPU cooling fans help it cool more
Some GPUs have bigger fans higher than others
such as the Gigabyte Windforce fan has 90MM and MSI Armour has an 87MM I know its a small difference but does it affect Cooling?
Sep 21, 2020
19
4
25
Larger fans offer higher airflow at lower RPM, which subsequently means greater cooling potential for a lot less noise. Picking up fans with greater CFM, or cubic feet per minute, will result in higher airflow and greater cooling – although you may have to trade higher noise levels.
Sep 21, 2020
19
4
25
Thanks! Do you recommend me getting the one with a bigger fan
