I've seen a lot of mixed opinions on this. Many people have told me that the package temp displayed in HWMonitor is usually 10c or so above the actual core temp, Iv'e also tried using CoreTemp and cant' seem to get a reading at all. My package temperatures in HWMonitor while gaming at different performance levels seem like they would be accurate, but I'm running with an open case, and even when my temps are approaching 74c the air from my cpu fan is cool and the heatsink seems cool to the touch. I've also seen a lot of posts stating that HWMonitor doesn't give accurate readings for these APU's ( A8 5500 ). I'm unsure if it's safe for me to have my cpu locked at 90-100% utilization while gaming because temps float between 65-70c and sometimes approach 75-78. If I lock my cpu to 90%, my temps normally don't exceed 65c even while recording, but I notice a slight performance loss (playing WoW very cpu intensive, and horribly optimized for amd chips). I would rather run at 100% for better performance, if I can do so safely without burning up my cpu. All of the mixed opinions make me unsure if these temps are accurate or if they are on average above the actual core temps.
TJ Maxx for this APU is 71.3c
If these temps are accurate, I think I'll be safe parking at 90% and taking a minor hit to performance
If these temps are inaccurate, I need a way to get accurate readings, because I'd really like to be able to run at 100%
Reason for setting cpu minimum so high, is because WoW is very cpu intensive, performance is much more stable when doing this, and temps seem fine if locked at 90%.
Any help is appreciated, thanks.
Temps while parked at 90% and showing Core Temp readings???
Temps while parked at 90 and gaming
Temps while set to 90-100% gaming + recording
