Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
I just ran the Intel utility that verifies your HyperThreading. At
home, on my P4p800, it passes, but on the machine I built
for the office, using a p4pe2-ex, it fails. I am running a Prescott
chip on the one that fails.
When I bought the chip, I did not realize that the MOBO would
not use its capabilities, such as restricting the speed to 533 instead
of 800 FSB.
In the future, I'll try to do a better job of selecting the right
MOBO/CPU combination. I bought the Prescott because it was at a
good price.
Is there a BIOS upgrade that will solve this Prescott / Hyper
Threading issue ?
Thanks,
Louis
On Mon, 27 Sep 2004 01:28:47 -0700, Guru wrote:
>On Sun, 26 Sep 2004 08:03:52 -0400, Jacko <Jacko@Bene.com> wrote:
>>Does hyper threading need two DDR RAM to work? If I put just one stick
>>of DDR RAM into a dual-channel capable motherboard, Will hyper threading
>>work?
>Only if it's CAS 2, 3, or 4.
