Does i required PSU?
Hritish
71
I will buy i5 processer +10gb ram + geforce gt 610 2gb + 1tb hard disk + i have 250w PSU does i need bigger w PSU? If yes so what will be its price? And tell me model also pls ! thx for help :))
yes brother you must have minimum 450W PSU for run these component without any prob ,,,,,,,,, if u belongs from india than i suggest you go for Corsair VS450W PSU,This is very good PSU in 450W This PSU runs your mentioned all component on good flow ,,,,,,,& this is also very cheap price point.
What model is the i5 and also the psu brand you have as I would say that 250w is adequate for that setup but it does depend on psu quality.
Why would you go with i5 and Gt610 when intel hd 4600 you already have in your CPU will achieve same performance,also going 10 gb ram will you go with 4+4+2gb cuz you will lose dual channel performance or you can go 4+4+1+1.You didnt tell us your main purpose for which your are building this PC.
