Hello everyone, I have an old PC that I want to use it. It has an Intel DG41WV motherboard in it. Before it has a 2GB Kingston DDR3-1333 stick in it. It works fine all the time, But 2 GB is to little.😀 So I decided to buy a matching stick and install it. After install it the PC boots. When I checked the bios it says that only one stick is installed. I tried swapping the sticks around and still the same. I even test both of the sticks on another PC. Both are fine. So then I tried a new stick that I buy more for it. Now the motherboard beep 3 times (Memory Error?
) So I tried everything I can but it doesn't work. Then I end up with only 2 GB of ram.
Well, I already know that it supports 1066/800 mhz sticks. But the 1333 sticks work on it.
So anyone know that does the mobo support the 2*2 DDR3-1333 sticks?
