Does IPS LED really use so little power?
Prit369
12
http://www.lg.com/pa_en/monitors/lg-25UM58/technical-specifications#
Says the usage is 27 watts... I currently use a Dell 2707 which uses close to 90watts. I have another 19inch Viewsonic which uses ~13w (probably the most energy efficient 19" LED I know)
I've been searching for a new energy efficient monitor for awhile and I find it hard to believe that a 25inch ULTRA WIDE uses just 27 watts since most 25-30" ones I've checked use minimum 60-70w.
The 34" uses just 41w... wow
http://www.ebay.co.uk/itm/Brand-New-LG-34UM56-34-21-9-Ultra-Wide-Cine-View-Monitor-/221773861232?hash=item33a2c09170:g:LsEAAOSwstxVVnq1
Is this actual usage? or some gimmick with all contrast/brightness to low lol
That's a slightly smaller monitor, which will reduce power draw a fair bit.
Often, especially on newer monitors with efficiency targets, the power draw is measured when the brightness is turned down fairly low - if you have the monitor bright, you'll use more than spec.
Depending on what you're measuring your monitor with, it may be over-reading. Cheap kill-a-watt devices are notoriously bad on loads with poor power factor.
But yes, monitors have come a long way. LED is only part of this; the electronics now use far less power too.
Latest posts
