I need a mid tower atx case and I've been looking at alot of reviews and its hard...
I am doing a ryzen build and in order to get the best of the cpu auto overclock, it needs to be stay cool. I already have a noctua heatsink NH-DH14 which I will use and I will also use noctua fans in my case. I know that the case itself can only do so much to reduce sound, the main thing is to choose quiet component, but still, a case that is more open will result in more audible noise... however a case that is too closed will suffer in terms of thermals.
I like the looks of the fractal design R6, but it is a bit on the expensive side and the thermals arent very good, its a bit on the warm side. Fractal does have a Meshify version which i find very nice looking but that one is full open mesh front and top, so, in terms of noise its worst than a lot of cases.
I have no problem replacing fans that come with the case with noctuas or other silent ones if thats needed, but if so ideally the case would be cheaper to offset the extra cash i would need to spend on silent fans.
Having a glass side panel isnt absolutely necessary, although I do kinda like the look. I dont care about RGB.
Basically it seems like quiet cases are often bad in terms of thermals, and good airflow cases are often ugly and bad in terms of noise... Isnt there a case that is good at both or that is well above average and well balanced? With filters that are easy to clean etc...
One other thing which is minor, but if the power/reset button could be located on the front instead of the top... My current case has those buttons on the top and i need to keep something covering the buttons otherwise my cat will press those at the worst possible time of course...
Thx!
Thx!
