Unless the motherboard is based on a CPU with more than usual PCI-E lanes, the first PCI-E slot, next to the CPU is the only appropriate for a GPU. There are some motherboards that use a PLX chip (usually denominated "Gaming" or "SLI edition") with 2 16x PCI-E slots but even in those cases i recommend putting the graphics card on the first slot.
That will depend on the make/model of the motherboard. Normally, you put the first card in the first PCIe x16 slot.
i have a wifi card as i can not move my router and i cant have a dual slot graphics card but there is another 16 pci further down my motherboard can i use that instead or not?
Again, it will depend on the make/model of the board as to how many lanes you will have available at that slot. Some boards with 2 slots are x16, x16. Some are x16, x8. Some are x16, x4. Some are x8, x8.
And it would be nice if you'd tell us your gfx card too.
Move the Wi-Fi card to the slot further away from the CPU, and put the video card in the long slot closest to the CPU.
A wi-fi card only needs 1 or 2 PCIe lanes. A video card needs 16. So make room for the video card in the first long slot or the cards performance will suffer.
can you take a picture of your PC opened and supply the motherboard brand and model please?
