Does it matter what pci-e slot I put my graphics card in?
Mad Mex
43
I have the Gigabyte GA-F2A88XM-D3H motherboard. I have the RX 480. I can't install it in the first slot because my radiator is in the way so I was wondering if I could put the card in the second slot without issues.
Thanks
WRONG ....YOU WILL LOSE performance running it in the second slot , it is only X4.
1 x PCI Express x16 slot, running at x4 (PCIEX4)
It states it on the specs page:
1 x PCI Express x16 slot, running at x16 (PCIEX16)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
