does it use more cores and threads or more clockspeed
swojas12
65
i really want to know that does 3d modelling application like (Autodesk Maya) and a game engine
like (unity) use mare cores or does it use higher clock speed
please suggest me a pc build under 60k rupees
thanks a lot
Depends really.
For rendering a lot of cores with high single core performance is nice. But that scales pretty well so a lot of slower cores but a lot more will also work fine.
Games depending on how you make them can use 1-infinite amount of cores. However today 4cores+ is the quite standard.
Clock speed really doesn't matter since every cpu generation is different and a previous gen at 1ghz can match a new gen at 2ghz so to say and opposite. You need to look at tests too see which is better.
Depends really.
