[SOLVED] Does load line calibration not work with manual voltage override?
Phaaze88
Estimable
On a x299 prime deluxe, I can get a stable 4.3ghz all core(7820x) at 1.085v on LLC 1.
Going any lower even when using the recommended levels 4 or 5, it crashes - just bumping down to 1.083 is no good.
Am I right to assume that LLC was intended for adaptive voltage settings?
Oops, posted this in the wrong section. Should be in the overclocking section, I believe.
Phaaze88
Estimable
After playing around with settings for awhile longer, I've come to the conclusion that LLC does nothing if one is running manual override.
It's for running in adaptive/offset mode. While I was looking around on other forums, I didn't see a clear cut answer to this. Oh well.
Similar threads
