P Pwnin Honorable May 4, 2013 8 0 10,510 May 5, 2013 #1 Does a mATX motherboard work with an ATX case. Its my first build and im not sure. Thanks
Solution diellur May 5, 2013 Generally, yes. Check the case specs to confirm, but the mATX motherboard screws line up with screws on the ATX board, so they should be compatible.
diellur Distinguished Apr 7, 2011 1,345 0 19,460 May 5, 2013 Solution #2 Generally, yes. Check the case specs to confirm, but the mATX motherboard screws line up with screws on the ATX board, so they should be compatible. Upvote 0 Downvote Solution
USAFRet Titan Moderator Mar 16, 2013 179,757 22,100 184,590 May 5, 2013 #3 Yes. Cases have multiple mount holes, depending on the size. You should be fine. Upvote 0 Downvote
S swifty_morgan Illustrious Feb 10, 2006 13,565 1 42,960 May 5, 2013 #4 yes. no worries. Upvote 0 Downvote
S sharingan5 Distinguished Feb 19, 2013 329 0 18,810 May 5, 2013 #5 Most ATX cases also support mATX motherboards. Upvote 0 Downvote
