does mhz matter?
Mikkel_1
18
i got two F3-12800CL7D-4GBRM 1333mhz and i want more ram so is it ok if i put in two HyperX Savage DDR3 2400MHz 4GB? or will it mess my pc up?
so if i swap them out then i can use my pc as soon as i turn it on or what?
so if my motherboard only can take 1800 mhz then i cant use those ram right?
theese are good right? HyperX Fury DDR3 1600MHz 4GB
Look good. just make sure buy the pair(2x 4GB)
the pair? aint buying 2 good enough?
2 individual? no. when you buy a pair(2x 4GB), they tested in the factory to make sure it work together.
2 individual usually works but sometime don't.
so this : https://www.komplett.dk/product/812852/hardware/hukomme... dont work?
It said a 2x4GB kit. not 2 individual
