[SOLVED] Does mining with an RX 5700 blower fan at 4000 rpm dangerous for fan?
Apr 4, 2021
8
Core clock MHz = 1750 default
Memory clock MHz = 1860, default = 1750.
Power limit= -%25 (%75)
Fan Speed = %75 fix 3800 rpm, default = oto.
Sıcaklık değerleri;
GPU Core = 60-65 degree
GPU Memory = 72-78 degree
GPU VRM Core = 52 degree
GPU VRM Memory #1 = 61 degree
GPU VRM Memory #2 = 62 degree
GPU hot spot = 68 degree
performance 53.~ MH/s
Are those temps and fan rpm safe for long period, thanks.
from where ?
You find a pic of your card with a close up of the power components. They have a mfg number on them you can reverse engineer. There's only a small handful of companies that make these chips appropriate for these uses.
Or you rip down your card and look up the part numbers yourself. That's what buildzoid and gamers nexus does.
In all honesty, there's no point worrying if the fans are going to be damaged. Mining puts a lot of stress on the card and in turn dumps heat, you need to evacuate the heat as fast as possible. For which you shouldn't be making a custom fan curve with respect to lower noise, leave them on Auto.
Reactions: krygennn
thanks for the reply.So what u think about gpu memory temp.Do you think 76-78 degrees damages memory chips(VRAM) at 7 24 usage ? thanks
Can you give me a brief opinion about my over all temperatures
Sıcaklık değerleri;
No matter what you do you hasten the life of your video card through mining. Power components have a mtbf power curve. And so do caps. While mining does not hit the super high end of the power curve, running it 24/7 will reduce the usable lifetime by years.
If you insist on mining those are reasonable temps.
Reactions: krygennn
No matter what you do you hasten the life of your video card through mining. Power components have a mtbf power curve. And so do caps. While mining does not hit the high end of the power curve, running it 24/7 will reduce the usable lifetime by years.
In which scale I am hastening my GPU ? For example in long period with these temps, how long can my card live
It varies by card to card depending on design.
10% power might give you 15,000 mtbf
75% power might give you 7,000 mtbf
100% power might give you 2,000 mtbf
This is a gross hypothetical other than. To demonstrate it's an exponential curve of decay
Buildzoid would have access to such data sheets. But you have to know arrangement and each part #
im running with 75 percent.How many years does 7000 mtbf corresponds
Using the gross hypothetical numbers from digitalgriffin:
A)10% power might give you 15,000 mtbf
-625 days, or 1 year and 8 months, if done 24/7
-1250 days, or 3 years and 5 months, if done 2/3 day
-1875 days, or 5 years and 2 months, if done 1/3 day
B)75% power might give you 7,000 mtbf
-292 days, or 9 months, if done 24/7
-584 days, or 1 year and 7 months, if done 2/3 day
-876 days, or 2 years and 5 months, if done 1/3 day
-83 days, or 3 months, if done 24/7
-166 days, or 5 months, if done 2/3 day
-250 days, or 8 months, if done 1/3 day
Reactions: krygennn
Phaaze is quite correct. However these are pure hypothetical numbers. You would have to pull data sheets to be sure.
